Re: Off topic, shaft vs bearing ID size
Posted by scotty on April 20, 2006 at 06:06:03 from (199.231.49.128):
In Reply to: Off topic, shaft vs bearing ID size posted by Jimer on April 19, 2006 at 19:34:54:
Mornin Jimer,
OK, here is a quick way to convert mm to english. 30 mm x .03937 = 1.1811. You had this figured out allready but thought I would post it for you.
Very seldom is there much of an interference fit between the shaft OD and the inner bearing race. Usually this is a line to line fit or just slightly smaller on the shaft OD. With that being said, you would need to have .0065 removed from the shaft to accomodate your 1.1811 inner race.
Hope this helps!
scotty
