Re: Farmall A - Starter, battery or Solenoid
Posted by Tallperson on April 20, 2006 at 12:50:59 from (165.170.128.66):
In Reply to: Farmall A - Starter, battery or Solenoid posted by plh_in on April 19, 2006 at 18:42:40:
I just had the starter rebuilt on my super m. It would just barely turn the motor and you had better catch it on the first turn or you were done. The rebuilder showed me the back plate. The babbit bushing had worn out and the rotor shaft had worn a slot in the housing down about a quarter of an inch. THe top brushes were not even touching anymore.. Put the new rebuilt starter in and I thought air flow from the radiator fan alone was going to pull the tractor out of the shop.. Man whata differance... I'd say get the starter rebuilt. Good luck Tallperson
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
