VOLTAGE REGULATOR
Posted by BOBM25 on April 21, 2006 at 04:41:54 from (63.166.24.194):
The voltage regulator on the smta is not working correctly, I think. Top set of points won't stay closed tight enough to charge battery. If you push them together with a screwdriver gauge says its charging, soon as you let go, gauge goes to discharge. Tractor has brand new battery and voltage regulator is only about year and a half old. Never did really charge right from the get go. Only good for half a dozen starts or so, then would be dead. Do I need a new regulator? They are about 40 bucks. I don't want to buy one if I don't have to, but I'm getting tired of jerking this thing around the farm. I did the whole polarize the generator deal when I changed the regulator. What do you guys think?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
