Re: High Idle Loping
Posted by Bob M on April 21, 2006 at 05:23:44 from (151.190.254.108):
In Reply to: High Idle Loping posted by NSC on April 21, 2006 at 04:19:53:
Most likely the carb high speed mixture screw is set too lean. (With the engine at operating temperature turn the screw CCW 1/4 turn at a time and see if it improves...)
Otherwise problem is stiffness in the governor mechanism itself, or somewhere the linkage between the governor and the carb throttle shaft. (With the governor cover removed, the engine stopped and the governor handle set at idle, the governor output link should move up and down freely with light finger pressure.)
