Farmall Tractors Discussion Board
Saginaw 3 point for H
Posted by Joe on January 14, 2000 at 12:12:58 from (206.58.190.15):
After looking at the Saginaw 3 pt. picture it's not clear if it is fed by two hydraulic lines or is there a T and one line feeds both cylinders.Do the hydraulic hoses come with the kit? Is the kit complete? BTW I finally got the H changed to a 12 volt. Used a Delco one wire alternator ( fit on old belt and under the hood), used a resistor on coil wire and a 12 volt battery. Added some 12 lights. Works great! Thanks for the help.
Post A Followup
: Re: Saginaw 3 point for H
