Farmall Tractors Discussion Board
Re: Saginaw 3 point for H
Posted by John.CO on January 15, 2000 at 08:46:49 from (12.74.90.67):
In Reply to: Saginaw 3 point for H posted by Joe on January 14, 2000 at 12:12:58:
Hoses are not included. You can run two hoses from your belly pump or use a T. If used as single acting, you'd put a vent in the second port of the cylinders (I think Darwin supplys these). Or you can run your pump through a DA valve (return to the drain port) and have down pressure.
John, tOTG
Post A Followup
: Re: Re: Saginaw 3 point for H
