Re: trans.
Posted by the tractor vet on April 22, 2006 at 05:29:12 from (64.179.117.165):
In Reply to: trans. posted by everado on April 22, 2006 at 04:45:23:
Just keep on slamen it and you'll be realy screamen on the price of fixen it > As there is no real adjustment to it if the shifter is in nuterual and ya have hi and low but rev. does not go in wright then guess what it is time to dig into your mouldy check book old coffee can or the old sock as it is time to stimulate the economy as there are parts needed to be REPLACED and also ya went and let the clutch and T/A adjustments go to long . It is like this if you have to slam and jam a shifter on a farmall to get it in or out of gear then the clutch and T/A adjustments are out and because of this theyget hard to shift and nobody realy take good care of there tractors in stayen up on adjustments . Clutch adjustments should be checked every year along with tune ups timming valve adjustments on gassers , Tractors are not a car or pickup that yua just drive them they are equipment that works in some of the worst cond. and things wear . People do not stop and think till they start to have a problem then it OH what is wrong here can i just adjust it , NOPE it's time to fix now . So what all is needed now depends on just how the tractor was treated over the years and how long she has been slamed to get rev. So you start at the top and end up down in the bottom as all the linkage needs to be tightened up and remove as much slop as ya can then it is getting into the range cover and fixen replacen what ever is loose then on down to the rev shifter and shifting fork and on real worse ones ya have to tear the whole rearend apart to replace gears and other pices and parts. So i need more info beside I HAVE TO SLAM IT TO GET REV.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
