Re: H carburetor - half gas, half kerosene
Posted by RustyFarmall on April 22, 2006 at 06:50:47 from (216.248.75.143):
In Reply to: Re: H carburetor - half gas, half kerosene posted by RustyFarmall on April 22, 2006 at 04:41:06:
I just looked at my H parts manual. The bottom part of the carbs are ALL 6212. The only differance I see between the kerosene, distillate, or gasoline carbs is the part number for the main metering nozzle in a low compression carb is different than the same part for the high compression gasoline carb. So if you use a kit for a gasoline carb in your kerosene or distillate carb, you will have a carb that is the same as if it came from the factory equipped to burn gasoline.
