Re: 686 Starter problem
Posted by Janicholson on April 22, 2006 at 19:13:28 from (66.173.50.129):
In Reply to: 686 Starter problem posted by Rollie NE,PA on April 22, 2006 at 09:50:12:
I would look, and measure carefully the flatness and squareness of the mounting surface for the starter.
There can be several problems, like ovaled out bolt holes (from the cracked starter, or bad fron the factory surfacing of the mount surface. There may be a new (and supposedly much better) pinion available from Case IH dealers. I'm not sure which models, but it might be worth the research. Good luck, and thanks for helping others.
JimN
