Re: Well, I did it - Piston Chiseling, Part 2
Posted by Bob on April 24, 2006 at 08:17:56 from (64.21.249.40):
In Reply to: Well, I did it - Piston Chiseling, Part 2 posted by JohnG(TX) on April 24, 2006 at 08:03:26:
That outcome was certainly predictable!!!
Likely, either the block damage can be cleaned up a bit and a new sleeve intalled with sealer, or the block can be bored for a repair sleeve.
Next time, drill a hole in the piston, and use a Sawzall! Or press the piston and sleeve out together.
