Re: 140 Lift and Cushion Spring
Posted by Hugh Mackay on April 24, 2006 at 14:36:49 from (209.226.106.71):
In Reply to: Re: 140 Lift and Cushion Spring posted by Avery on April 24, 2006 at 10:50:44:
Avery: I double checked on those chains, about 36". With hitch up all the way, put the chain around shaft portion of rear rockshaft, go down and around the round cross bar. I put one on each side and install them in a figure 8 pattern. Then just lower the hitch so chains take the weight.
