Re: While I'm Beggin' For Help (Long)
Posted by banjo on April 25, 2006 at 18:46:55 from (65.67.203.19):
In Reply to: While I'm Beggin' For Help (Long) posted by Allan In NE on April 25, 2006 at 18:32:21:
Had a74 chevy 350 once that the dist. had slop in and it would run good till you pushed it hard then it would spit,backfire,miss.readjust points and it would run good till the next time.
personally i do not know if it is the plugs or not, try switching the plugs around and see if it is the same plugs in different cylinders that foul.
