Re: While I'm Beggin' For Help (Long)
Posted by K.B.-826 on April 25, 2006 at 19:01:36 from (68.115.91.40):
In Reply to: While I'm Beggin' For Help (Long) posted by Allan In NE on April 25, 2006 at 18:32:21:
Allan, two things. Is your distributor advance working correctly? Those springs can get awful weak and then timing will be off. Are you running low-ash oil? It is extremely important that you do so with an IH 6 cylinder gas. They are designed to allow more oil down past the valve guides than most other engines. Running non low-ash oil WILL result in fouled plugs and deposits on the valve seats. You can always tell who isn't running low-ash, they're the guys who burn a valve every other year.
