Re: While I'm Beggin' For Help (Long)
Posted by Will Sick on April 25, 2006 at 19:16:26 from (207.177.50.189):
In Reply to: While I'm Beggin' For Help (Long) posted by Allan In NE on April 25, 2006 at 18:32:21:
I had the same thing with a 263 engine in a 706. It was the plugs. A cold plug will work fine when you are working it hard,but then you need a hotter plug for light work. If I had the hotter plugs it would have pre-ignition when I puy it under a heavy load. I solved the problem by putting electronic ignition on it and leaving in the cold plugs. The electronic ignition will fire the cold plugs for light work and work fine for a heavier load. It hasn't missed since I put in the electronic ignition and needs a lot less choking when it's first started.
