Re: H smoking
Posted by River Bottom Farmer on April 25, 2006 at 19:26:01 from (64.12.116.65):
In Reply to: H smoking posted by Tom Windsor on April 25, 2006 at 19:12:13:
I will almost bet you have some stuck ring.I would pull the plugs and fill it with tranny fluid right after you run it and get it warm.After doing this I would run it for a while it will take some time for the tranny fluid to burn out of the cylinders.I did this on a 9n ford and it finally worked after 3 or 4 times.Just make sure and change your engine oil after doing this or you will wind up with a lot of tranny fluid in your crankcase.Doing it after its warmed up will help pull the tranny fluid in between the ring and the piston and help brake them loose from the ring groove .Check you compression before doing this you may only have one cylinder with a stuck ring....Hope I could help River Bottom Farmer
