Re: Farmall Cub Stops
Posted by Levi K on April 27, 2006 at 05:58:54 from (69.66.187.86):
In Reply to: Farmall Cub Stops posted by Sonny Varnell on April 26, 2006 at 20:25:08:
I had something similar happen to my 300- I was fine one minute an then the next it would only run at a low idle then die. Opened up the carb, was so dirty that the float only had about a 1/4 inch to move. So, yeah, it's probly the carb
