Re: I've been given an H
Posted by old on April 27, 2006 at 08:07:00 from (207.69.137.9):
In Reply to: I've been given an H posted by Jugum65 on April 26, 2006 at 21:59:52:
Couple of things to do first. Pull the oil drain plug from the engine and have a look see what might be in there. If you find a bunch of junk up in there when you try to drain it pull the pan. Is the engine loose or locked up?? Either way I would fill the cylinders with tranny fluid to help brake things loose, the rings even if the engine turns are probably sticking to the pistons
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
