Re: help 706 quits under load
Posted by Nat 2 on April 28, 2006 at 05:03:35 from (64.80.108.52):
In Reply to: Re: help 706 quits under load posted by jbwny on April 27, 2006 at 19:37:28:
You are correct. If the tractor continues to run by pulling the choke, then it is NOT an ignition problem. The choke affects fuel flow, not spark.
You have a carburetor problem, or a general fuel flow problem. If the sedimEnt bowl is clean, that's a start but it doesn't mean that the hole in the bottom of the gas tank isn't plugged up with bits of rust and crud.
My personal opinion is that it's internal to the carburetor, as pulling the choke allows the tractor to continue running.
You would be a fool to listen to those technophobes who are trying to hand you the line that the electronic ignition is the problem. They're crotchety old farts who fear anything they do not understand with prejudice.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
