Re: 806 electrical trouble
Posted by John T on April 29, 2006 at 12:38:13 from (66.244.90.5):
In Reply to: 806 electrical trouble posted by chadd on April 29, 2006 at 11:41:47:
Heres how I wire a GM 10SI Alternator on gas tractors using a coil ignition system, if its on a Diesel, they can be excited by use of a Normally Open Oil Pressure Switch with a hot wire feeding its input and its output used to excite the alternator via the 10 ohm current limiting resistor (see below) when she sees oil pressure and remember, it requires NEGATIVE GROUND !!!!!!!
The big rear main alternator output terminal goes to the wire that used to be connected to the BAT terminal on the Voltage Regulator or Cutout Relay. HOWEVER if that wire wasnt already upgraded, when I convert from a Genny to an Alternator, I replace that wire with a 10 Gauge and it runs from the alternators main output up to the LOAD (NOT to battery/starter) side of the ammeter. I also replace/use 10 Gauge from the ammeters other SUPPLY terminal to the battery/starter.
The little side number 2F Voltage Sense Terminal gets connected (use a short 14 jumper wire) right up to to and with the big main output terminal mentioned above.
For the little 1R side Excitation Terminal, run a 16 or so gauge wire from the ignition switches IGN (which is HOT ONLY when ignition is turned on) terminal and in series with it place a 10 ohm 5 watt current limiting protection resistor (dont really need that much wattage power rating, but they are heavy duty built and easy to wire). Then in the rare event a gas tractor continues to run cuz of alternator backfeed when the ignition is switched OFF, I add in series a 5 amp 50 PIV minimum Diode. The diode must be wired with negative cathode end to the alternator and positive anode end to the switch. Again, the ratings are not that exact but about any diode over a few amps and 50 volts or so works.
Dont forget to change the battery to negative ground (if its not Negative already) and if a gas tractor the coil needs to be wired so the negative goes to ground via the distributor points and the positive gets power from the ignition switch and you have to reverse ammeter leads also if your changing polarities from Positive to Negative.
Good luck Ol John T in Indiana
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
