Re: ? about rear cultivators on super A
Posted by Mark on April 29, 2006 at 19:31:18 from (172.162.251.252):
In Reply to: ? about rear cultivators on super A posted by banjo on April 29, 2006 at 18:23:01:
banjo,
I see the rear lift rods for sale on ebay all the time...be better off to buy a set and be done with it.
The front lift arm spring is also a shock absorber and applies down pressure on the shovels but allows them to spring up if you hit a hard spot or object.If you will notice when you drop the front cultivators, the arm at the hydraulic unit will continue back against the spring..stretching it ever so much...this is what the set screws do..adjust the spring stretch/tension. Clear as mud? Just look at and watch it work..you'll figure it out.
