Re: Carb Adjustment on 350
Posted by CNKS on April 29, 2006 at 20:08:29 from (204.249.178.138):
In Reply to: Re: Carb Adjustment on 350 posted by RustyFarmall on April 29, 2006 at 17:49:00:
This is a direct quote from page 37 in the Super H operators manual: "The carbuetor on the gasoline engine is equipped with a main fuel adjustment screw which can be used to reduce the amount of fuel going into the engine when under light load conditions. However, when heavy work is to be performed in which the full power of the engine is required, the fuel adjusting screw should be set five turns off its seat. The fuel adjusting screw seat in the gasoline carburetor has been calibrated to provide a full-power mixture and should not be restricted by use of the adjusting needle when the full power of the engine is required." That said, I have not used my SH for "full power" conditions, and I can't say how much it can be turned in for light load conditions. All I know for sure is, I put a kit in it, assuming it was adjusted just like the carb on the non-super H or M (I have both of those also). It would not even go up a slight incline without sputtering -- that's when I read the manual. It might run fine 3.5-4 turns out for my use, I have not tried it. I doubt seriously if it will run worth a darn 3 turns out though, as that would be about where it was when I first adjusted it. The carb is not the same as either the H or M carb.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
