Re: power steering 300 U
Posted by Red Rider on April 29, 2006 at 20:55:40 from (66.235.45.149):
In Reply to: power steering 300 U posted by Wes in Ohio on April 29, 2006 at 14:03:04:
Ok Wes the picture and some of the lines are not quite according to the parts manuel. Which If you had one it would answer all your questions. Let me see If I can explain The hydraulic situation for your power steering. First off If your tractor did not come with power steering you will have to get a pressure regulator for power steering. The power steering regulator has a priority valve in it to give the steering priority. There is a fitting out the rear that powers your power steering motor. The other line from your power steering motor is the return which according to the part manuel return through the drain plug. The U shaped tube that also comes off the regulator valve feeds the front two hydraulic valves if your tractor has them. The reason for this is so the front one or two valves work through the pressure regulator. I hope this helps. Really you should get a hold of Binder Books and get your self a set of manuels.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
