Re: Can't get 460 runnin'
Posted by Allan In NE on May 09, 2006 at 12:40:08 from (148.78.243.25):
In Reply to: Can't get 460 runnin' posted by tractor blues on May 09, 2006 at 12:33:42:
Bad switch, bad wiring or bad ignition resistor. It's running on the full 12 volt "start" circuit.
Allan
