hot side of starter solenoid
Posted by Wes in Ohio on May 09, 2006 at 12:53:57 from (72.11.31.220):
How would I go about finding out which lug on the starter solenoid is hot.. their happens to be three on this one, two large and one small converted my 300 u to 12v negative ground with an alternator
Thanks
Wes
