Re: hot side of starter solenoid
Posted by El Toro on May 09, 2006 at 13:12:46 from (205.188.116.133):
In Reply to: hot side of starter solenoid posted by Wes in Ohio on May 09, 2006 at 12:53:57:
You need to use a volt meter to determine which terminal is hot. The terminal with an "s" is only hot when engine is cranked. Hal
PS: The terminal that has voltage usually feeds voltage to your ignition switch. Your car or truck is wired this way too.
