Re: Farmall M what next
Posted by Janicholson on May 09, 2006 at 13:05:07 from (199.17.6.175):
In Reply to: Farmall M what next posted by sccwells on May 08, 2006 at 20:28:42:
The corrosion of the aluminum piston can expand so much that it puts drastic pressure on the cylinder wall, locking the sleeve in the cast bore beyond its press fit. I would buy or borrow, or make up, a fly cutter (machinist term for a one cutter hole cutter with a short blank center locater that goes in a drilled hole in the center of the piston). It would be 1/8" smaller than the bore diameter. I would machine away the top ring land (and remove the top of the piston). Once the top is removed, there will be no center hole to use, but a saws all should be able to cut out to the back of and through the remaining compression piston rings, cast iron is easy to cut. (be careful to stay parallel with the cylinder). Once the tension is off the circumference of the piston, it will move. Just my way of doing the deed. JimN
Home
| Forums
Today's Featured Article -
New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
