Re: Can't get 460 runnin'
Posted by El Toro on May 09, 2006 at 13:20:52 from (205.188.116.133):
In Reply to: Can't get 460 runnin' posted by tractor blues on May 09, 2006 at 12:33:42:
I think you have a bad ballast resistor. Run a
separate hot wire to the coil and see if it will run. Hal
PS: If it runs you will need to disconnect the wire to the coil to get the engine to stop. Is the coil 6 volts? You could use a 12 volt coil and eliminate the ballast resistor.
