IH 424 -- throttle problem, need some help
Posted by Darryl-KY on May 09, 2006 at 15:24:51 from (63.19.125.7):
I have a 1966 IH 424 utility -- it's been a good work tractor since I bought it three years ago. I was using it today with a post hole digger when it dropped from 3/4 throttle to idle. I thought something might be wrong with the linkage, but it was still attached. Moving the throttle lever only changes the rpms very slightly. When the problem first occured (it was sudden with no warning), moving the throttle lever to the idle position cause a rattling sort of sound. This sound stopped.
I noticed that the throttle linkage doesn't attach to the carb but, rather, heads toward the hydraulic pump (I think). I need some advice on what and where to look in order to get things operational again. It still runs fine (at idle speed) and everything else seems to work fine.
Thanks!!
Darryl
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
