Re: value of a 350 utility
Posted by PAULIH300 on May 09, 2006 at 18:02:18 from (205.188.116.133):
In Reply to: value of a 350 utility posted by Frewheelin' on May 09, 2006 at 16:07:40:
If it has TA make sure it works.Check the water pump for leaks.Rebuilt 300/350 pumps are pricey! And the infamous steering.If it has any freeplay (like 1/2 a turn)the box is heavily worn and not easily fixed.If its power steering look for leaks out the pitman shafts and up thru the steering column.Any of these deficiencies...either walk away or dicker them down more than $1000 lower than they are asking.
