Tire liquid question
Posted by Rick/Oasis ID on May 11, 2006 at 06:29:59 from (207.200.116.5):
I have read post talking about using windshield washer fluid in your tires.
1. Is this recomended
2.standard or winter fluid preferred
3. Can i pull the valve core and fill it with a small elec motor and 25 gallon tank used for spraying weed killer. (seems like it would work)
4. where can you buy calcium if I can't use washer fluid
5. Tractor is a 300 11x 38 tires i think, how much fluid do they require
Thanks as always guys........Rick
