Re: Tire liquid question
Posted by Dr.EVIL on May 11, 2006 at 07:45:26 from (216.136.115.250):
In Reply to: Tire liquid question posted by Rick/Oasis ID on May 11, 2006 at 06:29:59:
Washer fluid works fine or used antifreeze, make sure the freeze point is lower than the lowest temp. You ever see in Your area. The fluid will expand if it freezes and destroy Your tires. The washer fluid will not weigh as much as the Calcium Chloride but it's close. I have 12.4 X 38's on My Super H, same size as your 11-38's, I seem to remember they hold 40-45 gallon of fluid each, about 500# per tire with the CaCl solution. Do a search on "Firestone" and they have quite a bit of info on ag tires on their website.
