Cowman can you help me?
Posted by Paul Shuler on May 11, 2006 at 12:40:11 from (170.29.248.3):
Hi Cowman. I need help. I have a 48 H and the needle valve went to leaking. Pulled off the bottom of the carb and the old gasket came apart so to get the rest of the gasket apart I needed to pull out the venturi. Well it was stuck tight and when I went try and twist it a little it just fell apart. No one around here has one. This is my mowing tractor and the grass is getting high. It is the H carb with a single float. Smaller than the super H.If you don't have one do you have any ideas where I might get one?
