Bolt holes on new manifold much larger
Posted by djp on May 11, 2006 at 17:32:32 from (152.163.100.65):
Just got my new manifold for my H. Noticed the mounting holes are drilled out to 7/16" and the two outer holes are drilled to 1/2". My studs are 3/8" so there's a lot of play there. Also, the carb mount holes are larger and elongated. My old one had 5/16" studs. Did the later H models and 300's have larger studs? Anyone else notice this with a new manifold?
Thanks
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
