Re: F-14 Gas Line Route
Posted by BMC-FFA on May 12, 2006 at 03:06:58 from (66.52.142.7):
In Reply to: Re: F-14 Gas Line Route posted by Fawteen on May 11, 2006 at 17:15:36:
Ours has only one cap. From what I can see, it is a single tank for gasoline. We have a parts tractor that has a tank with two filler caps and this is not like it. Should we put a sediment bowl at the tank that has a shut-off in it? Obviously we can run lines but we are also interested in making the tractor as original as possible.
