Re: Switching to a 12 volt Delco Remy Generator
Posted by JohnG(TX) on May 12, 2006 at 12:00:21 from (216.136.20.34):
In Reply to: Re: Switching to a 12 volt Delco Remy Generator posted by Nebraska Cowman on May 12, 2006 at 04:11:18:
How did you do that? Just change the regulator? I have heard that would burn up the generator. How long have you run it this way? I might consider this since I have no lights and I am running a magneto, so there would be no steady-state draw, just what is required to trickle-charge the battery from the initial start.
