smoking 450 diesel
Posted by sd 450 on May 12, 2006 at 20:48:50 from (24.220.159.99):
I am reviving a 450d and as one of the last steps drained the
injector pump oil which i thought looked quite thin (almost like oily
diesel!} Replaced it with 10w30 and now my 450 puts out lots of
white smoke if i go faster than an idle. It ran fine without smoking
up to this point. From the old post i'm guessing i have a seal out
but noone else was mentioning lots of smoke. Can i run it like this
without hurting anything, can i fix it myself or is there a place near
sioux falls that fixes these pumps
