Re: smoking 450 diesel
Posted by the tractor vet on May 13, 2006 at 07:05:52 from (64.179.117.166):
In Reply to: smoking 450 diesel posted by sd 450 on May 12, 2006 at 20:48:50:
Well a 10w30 is not the oil that you run in it , but white smoke is not a good thing as that is and indacation of low compression . As far as doing much to the Injection pump yourself other then maybe replacing the primary pump seal that is it , the rest must be done at a pump shop . Now your white smoke could be that the decompression valves or starting valves are not closing all the way because of something binging the linkage and not allowen them to closes all the way. The oil that should be used in that engine and in the injection pump should be a 30W seires 3 diesel engine oil.
