Re: hey allen in ne and,or others
Posted by Steven@AZ on May 13, 2006 at 06:09:10 from (24.121.48.188):
In Reply to: Re: hey allen in ne and,or others posted by tn terry t on May 12, 2006 at 21:00:56:
It is a Cross brand pump. I believe it is a 50 series gear pump. It is designed for the side load of being run by a belt. It cost $180 in 2003.
The pump runs about 2000 rpm at full throttle and delivers around 16 to 18 gallons per minute at that speed. When the pump is running 1000 rpm it puts out around 8 gpm.
The max pressure the pump is rated for is 3000 psi. However, the belt drive will only deliver around 1200 psi before slipping (same psi as the distributor pumps). If I were to do it again, I might spend the extra money to put a cogged belt drive on it.
Need any more info, let me know. I have the overall spec sheet for the pumps, but I'm not sure exactly which model I have - I just went to a local hydraulic shop and gave them my specs for drive type and gpm and they ordered what I needed.
