Re: further 656 wiring issues
Posted by Janicholson on May 13, 2006 at 07:07:10 from (66.173.50.123):
In Reply to: further 656 wiring issues posted by charleskirton on May 12, 2006 at 14:56:20:
An engine that runs on start only is pretty easy to diagnose. It is running because the ballast resistor bypass wire is doing its job. It is stopping because the "run" ignition circuit is "open". Put it in neutral, turn on the switch to run (not start) check for volts at the coil (supply side, not dist side, and the other lead of the volt meter to good shiny ground). If none, my theory is correct. If none, follow that wire to the ballast resistor. check for volts there at the terminal that wire connects to (there may be another wire there as well, ignore it). If volts, the wire is bad internally. If none, check for volts on the opposite side of the ballast resistor. if volts, replace theresistor, and you are set to go. If no volts, follow that wire to its other end and check for volts. If volts there that wire is bad. The wiring on your tractor may include switches and safety devices so tracing the wire may require effort. Eventualy the circuit will get back to the ignition switch terminal that is ign. (hot when in the run position. if this has no volts, the switch may be bad, or the supply to the switch may be disconnected. If the start on this tractor is like on a car by turning the key switch to start, the switch is bad. If it is by push button, the supply to the switch is faulty. I hope this allows you to diagnose the problem. keep un informed as to what you find, it is as important as our messages to you. JimN
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
