Re: Just checking in
Posted by CNKS on May 13, 2006 at 14:25:03 from (204.249.178.138):
In Reply to: Just checking in posted by Michael Soldan on May 13, 2006 at 06:48:15:
You can buy cheap blood pressure units at a phamacy or Wal-Mart. I have used one for years and consider them reliable. If you want to check the reliability, check it against one that is known to be accurate.
