Lottsburg, VA
Posted by Bud Nolan on May 13, 2006 at 19:17:33 from (4.129.87.11):
I installed a Delco 10SI alternator in my Farmall 230 following the schematic for a Farmall Super M. The schematics are great; very easy to follow.
I did not install the WARNING LIGHT, but did install the BALLAST RESISTOR.
When the ignition is shut off the engine does keep on running!
I took the BALLAST RESISTOR out of the line but the result is the same. The engine keeps on running when the ignition is shut off.
However, when I disconnect the (+) wire from the IGNITION COIL the engine stops running immediately.
Evidently I have wired it correctly as the AMMETER
shows that the engine is charging when it is running.
Where did I go wrong? Que pasa?
Many thanks,
Bud Nolan
Lottsburg, VA
vamarinesurveyor@aol.com
