Re: A Charging Problems
Posted by Janicholson on May 15, 2006 at 06:38:00 from (199.17.6.175):
In Reply to: A Charging Problems posted by Doug Wilkins on May 15, 2006 at 06:11:05:
With a fully charged battery on the tractor but not connected to the Neg cable (best to charge it in this case with the Neg battery cable not connected), and all lights and ign off. Using a volt meter, check between the Neg post on the bat and the Neg cables clamp. (hook the Neg black lead to the post, and red to the clamp) If there is a reading more than .5 volts, there is a battery drain. This means the electrical system is leaking energy to system ground. If no volts (good) connect the battery Neg cable and start the tractor. If it charges good, check the voltage across the battery. Black on Neg red on pos. It should be 7 to 7.2 volts. If so it is good. If not that high, thr regulator needs to be adjusted (old automechanics books, and repair manuals needed here). If it does not charge, and tapping the regulator makes it do so, ai wouls replace the regulator. To repair current leaks(as in the second paragraph), remove one wire at a time ,from the electrical connections in the box, and then on the regulator, to see if it stops the voltage flow. If that wire does not change the drain, re-attach it. I hope this gives a starting point for your analysis. JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
