Re: Model H- Locked rear axel
Posted by jal-SD on May 15, 2006 at 08:31:25 from (71.32.34.112):
In Reply to: Model H- Locked rear axel posted by Rob Smitson in Oklahoma on May 15, 2006 at 07:51:15:
If you drained the rear end, a ball from a broked race might have gotten under the bull gear. Did you get any spare parts or filings out of the rear end when you drained it? H's kinda like to wear out the bearings on the axes and brakes and drop a ball or two once in a while. They will NOT go between the bull gear & the bottom of the housing, I've seen 'em break the housing when a ball tried to fit through there. (My $0.02 worth. jal-SD)
