Re: SMD sounds like John Deere - HELP!
Posted by the tractor vet on May 15, 2006 at 09:49:26 from (66.202.111.132):
In Reply to: SMD sounds like John Deere - HELP! posted by AGR538 on May 15, 2006 at 06:41:51:
Well , here are things to check . Pull the valve cover off and look for any valves that are not moving because of a broken push rod , broken rockerarm , broken valve spring . Stuck staring valve stuck down or broken staring valve spring . Now if you find nothing there then , i know you don"t want to here this but it is time to pull the head and look for burnt or broken valves . Now on them old diesels it gets even worse as it could be a cracked head or cracked block and they don"t always leak coolant just miss.
