Re: SMTA won't turn over
Posted by the tractor vet on May 15, 2006 at 09:57:29 from (66.202.111.132):
In Reply to: SMTA won't turn over posted by GordoSD on May 15, 2006 at 09:36:37:
I go along with the pull the plugs first and also drop the splash pan up under the ft. pulley and get a pipe wrench on it and see if you can turn it backwards you will have to put the T/A in the low side or block the clutch pedal down for it to turn backwards , also pull the started out as it may have locked in the flywheel .
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
