Re: SMTA won't turn over
Posted by Bob M on May 15, 2006 at 10:04:40 from (151.190.254.108):
In Reply to: SMTA won't turn over posted by GordoSD on May 15, 2006 at 09:36:37:
Could also be the starter bendix has jammed. If the tractor is on hard ground put it in 5th gear & TA direct, then try rocking it backard an inch or two. (When the fan blade moves at all the bendix has unjammed).
Or loosen the cap screws holding the starter to the clutch housing 7 or 8 turns, then pull the starter away from the engine a bit. If you hear a "clunk" inside the bendix has unjammed. Retighten the caps screws and try starting again.
Good luck!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
