Re: SMTA won't turn over
Posted by gene bender on May 16, 2006 at 05:13:57 from (66.43.221.211):
In Reply to: SMTA won't turn over posted by GordoSD on May 15, 2006 at 09:36:37:
Sounds like the starter is jammed take it loose so the bendix can release.
