Re: M won't start without starter fluid ? WHY??
Posted by Janicholson on May 16, 2006 at 06:50:29 from (199.17.6.175):
In Reply to: M won't start without starter fluid ? WHY?? posted by Sam F. on May 15, 2006 at 09:34:27:
If all the great ideas below do not produce results, try a new set of spark plugs. Sometimes the plugs will ignite the very combustable ether, but not cold gasoline fumes. Weak spark can also be an issue. The spark should be blue and easily jump 3/8" (with insulated pliers!!) JimN
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
