Wheel seal
Posted by Darin in Nebraska on May 16, 2006 at 09:45:41 from (68.96.26.76):
Hello everybody. I was wondering if anybody here has torn off the rear wheel on like a international 240 utility or something that might be similar? I can get the wheel off no problem but the hub is stuck on there. Is there a keeper ring or anything that holds that on? Would it be smart to apply heat to it or will that cause more problems? I would like to change the wheel seal on that side cause it leaks. Thanks for your time. Darin
