Re: not sure what i should do with this M
Posted by Michael Soldan on May 16, 2006 at 19:22:49 from (24.235.41.226):
In Reply to: not sure what i should do with this M posted by Paul G. in Mn on May 16, 2006 at 18:42:52:
Paul one of my H's had that happen, I had it welded and the guy did a real good job. If you are confident in the repair I wouldn't change trans housings, use it and see what time will tell, your other options are a lot of work, how's the rest of the tractor, ie everything else sound and worth the effort? Change over will be a big job, good luck, you've got the spare rear anyway if it has to be changed...Mike in Exeter Ontario
